The design and simulation software for heat pump systems
Efficient heat pump design with GeoT*SOL
GeoT*SOL
Are you looking for a professional and user-friendly software for the planning and design of heat pump systems? Then GeoT*SOL is the ideal tool for you.
GeoT*SOL offers you the choice between different heat sources (soil, air and groundwater), operating modes (monovalent, monoenergetic and bivalent) and numerous system configurations for your location. The program allows for bivalent systems with boiler as heat generator as well as the integration of solar thermal systems and photovoltaic systems.
Based on a dynamic minute simulation, electricity consumption, seasonal performance factors, operating costs and other system data can be calculated, taking into account blocking periods and tariffs. With these parameters, GeoT*SOL helps you to develop efficient and economical heat pump systems. Selected results can be conveniently incorporated into the project report for the client.
GeoT*SOL is available in English 🇬🇧, French 🇫🇷, Italian 🇮🇹, Czech 🇨🇿 and German 🇩🇪. Download your free 30-day trial now!
Product highlights
More product features
Licensing and pricing
GeoT*SOL
Named user license (1 year)
Dynamic simulation program for planning and designing heat pump systems.
385,00 EUR
plus VAT.
Buy now
System requirements and releases
System requirements
GeoT*SOL
  • Internet access
  • Processor: Intel i3, AMD Ryzen 3 or higher
  • RAM: 4 GB
  • Free hard disk space: 1,2 GB
  • Resolution display: at least 1280 x 768 pixels, 16 bit
  • Operating systems: Windows 10 (64 bit, latest service pack required), Windows 11 (64 bit)
  • Miscellaneous: Microsoft .Net Framework 4.8 (will be installed automatically)
You can download our free trial version and test whether GeoT*SOL can be run on your computer!
Release notes
February 11th 2025GeoT*SOL 2026 Release 2
The following new features and changes are included:
  • The user is now warned if the selected heat pump is discarded when changing the heat source.
  • In the database dialog, heat pumps can now be sorted by flow temperature.
  • Updated climate data based on Meteonorm 9 (2001–2020).
  • The license management client has been updated (improved stability).
The following bugs have been fixed:
  • Crash when entering incorrect values in the heat pump database dialog.
  • The calculation of domestic hot water requirements was performed despite incorrect input values.
  • The CO2 savings were not specified depending on the selected boiler (wood, natural gas, etc.).
  • In very cold locations, the X-axis in the bivalence point diagram was no longer legible.
  • In some cases, the bars in the results graphs were outside the diagram.
  • Warning in monovalent mode if the target temperatures were too high.
  • Some error messages were not translated into Czech.
  • The profile name was not translated in the project report.
December 3rd 2025GeoT*SOL 2026 Release 1
  • The lower modulation limit for heat pumps is now better taken into account in the simulation. This applies to both simulation and data entry. The product dialog for heat pumps has been revised in terms of performance data and operating limits for the display and entry of product data. This change often results in a slight increase in the seasonal performance factors, as the performance of the heat pump no longer drops as sharply. Furthermore, heat pumps that actually have increasing efficiency in partial load operation are now better represented.
  • In system WPA 8, the heat pump is only used for preheating domestic hot water. This significantly increases the boiler's share of the load, and the heat pump no longer has to deliver such high flow temperatures.
  • The product selection dialog has been updated and made clearer.
  • The bivalence point diagram has been expanded to include the minimum heating output of the heat pump.
  • The demand for domestic hot water can now also be entered as annual energy demand and specific annual energy demand.
  • Loading the database at program startup and database access have been accelerated.
  • New program language: Czech.
  • The databases have been updated.
  • Crash of the project report when a project image was selected on the Project Data page.
  • Crash when the product selection dialog was closed during a full-text search.
  • Crash when entering a custom soil type for the geothermal collector.
  • Graphic of the auxiliary heater in the bivalence point diagram was incorrect.
  • The flow temperature of the boiler was missing in the result graphics for bivalent systems.
  • The diagram type of the data series was not saved in the result graphics.
  • No brine water heat pumps with an intermediate circuit were permitted when groundwater was used as the heat source.
  • The flow temperatures in the predefined profiles of the result graphics were incorrect.
  • Crash when selecting certain domestic hot water storage tanks.
  • Seasonal performance factors were sometimes calculated and displayed incorrectly.
September 30th 2025GeoT*SOL 2025 Release 7
  • New interface to SOLAR-COMPUTER GmbH for importing building data.
  • New program language Italian.
  • Operating times can now be defined for heating and domestic hot water.
  • The results graphics are displayed in new colors.
  • Access to the database has been accelerated; the database is now loaded when the program starts.
  • The LM client has been updated.
  • When exporting the project report, content was missing if the preview was turned off.
  • Result graphics were displayed incorrectly, too large/too small.
  • Result graphics contained empty data series.
  • Tank losses were displayed incorrectly in the database dialog.
  • Error message during installation (vcruntime140.dll not found).
  • License was not released when logging out/shutting down Windows if GeoT*SOL was not closed beforehand.
  • In the options, the automatic update check was not displayed correctly and changes were not saved.
  • Own products were not transferred during a database update.
  • Heat pump utilization was not displayed correctly in the result graphs.
June 12th 2025GeoT*SOL 2025 Release 6
  • Program crashed when adopting self-generated climate data outside Germany.
  • Crashes when logging in with user-based licensing.
May 26th 2025GeoT*SOL 2025 Release 5
  • The design temperature is automatically set to the standard outdoor temperature (DIN/TS 12831-1 Part 1: National supplements) for locations in Germany. For all other locations, the coldest temperature from the climate data set is displayed and can be adopted as the design temperature.
  • The heating load and domestic hot water energy requirement are displayed in the project status.
  • Projects can be loaded, created or the last projects can be opened from the start page.
  • Elements can be shown and hidden on the interface to increase clarity.
  • Change in display of full load hours: All hours in which the maximum utilisation was reached at least briefly are now counted as full load hours.
  • Display of the source temperature for brine heat pumps in the sizing help diagram.
  • Project report supplemented with annual domestic hot water energy requirement and design temperature.
  • Search in database dialogue improved.
  • Databases have been updated.
  • Intersection point in sizing help diagram partially incorrect.
  • Partial crashes after saving the project report.
  • The tank database dialogue also displayed manufacturers that had no tanks.
  • In the first simulation, the generator heat output was sometimes not set.
  • Changes to the domestic hot water tank of the WPA 8 were not adopted.
March 13th 2025GeoT*SOL 2025 Release 4
  • Crash on the page Heat Generator if the supply temperature of the heating system was above 50 °C.
March 4th 2025GeoT*SOL 2025 Release 3
  • Sizing help for determining the size of heat pump and boiler.
  • An RSS feed is now available on the start page of the program.
  • Updated product databases.
  • Crash when defining a heat pump and entering incorrect values.
  • Increasing and decreasing the storage tank temperature with battery system was not possible.
  • It was not possible to increase and decrease the storage tank temperature with system HPS 1.1 and HPS 1.2 systems.
January 13th 2025GeoT*SOL 2025 Release 2
  • New system with space heating and buffer tank (WPA 1.1).
  • New bivalent system with space heating, buffer tank and boiler (WPA 1.2).
  • New diagrams for visualizing the operating characteristics (energies via temperatures).
  • New selection of high and low temperature heating circuits.
  • New version of MeteoSyn.
  • New license model:
    • Dialogs in French.
  • After changing self-created heat pumps, the database dialog was not updated.
  • Crash when naming self-created heat pumps.
    • Crash when starting GeoT*SOL (UUID not available on some computers).
    • Crash if the license file could not be written.
    • Crash in rare cases where an ini-file contained invalid content.
November 19th 2024GeoT*SOL 2025 Release 1
Contact
